Failed to set TCP MD5 password option because of sockets error.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Failed to set TCP MD5 password option. Sockets error code = %p1% Socket ID = %p2% Socket type = %p3% Socket family = %p4% Socket protocol = %p5% Application handle = %p6% Stub socket handle = %p7%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | xInt32 |
| p4 | xInt32 |
| p5 | xInt32 |
| p6 | uInt32 |
| p7 | uInt32 |
